Why did the pump housing change
kurtina2016
I had to order a new pump housing do to wear. When I took it apart I had a separate housing for the impeller, no wear ring on my model. 2018 SX195. I received a new housing from Yamaha with a new housing that has a wear ring. It is both pieces in one now. Has anyone encountered this? I just wanted the impeller side since that was the only thing that needed to be replaced. I now have to take the shaft and bearings out of the old and put into the new. I need some help with this and would greatly appreciate any info you may have. I have attached pics of my old housing (6075 and 6076 jpg) and the new housing sent in replacement (6077 jpg)
From my own experience, they changed one of the housing designs in 2019. My AR210 that year had the new design, but the 212X had the old one. I'm not certain which other models they're doing this swap for, as a few forum members have shown their newer models have those as well. My guess is that there's some issue with a supplier, or the design is less costly and they seem to be moving towards that version.
Are you certain that the part number was the correct one ordered, as usually they mention something about a new part number superseding the old one, and don't just ship you one that would require such drastic changes on your part. They've never failed to mention something like this with their oil filters or other parts, and this happens all the time with car parts as well. Can you hold off until you can call them and tell them the situation and get the correct part shipped, or perhaps check with another supplier for the one you need, and not the "improved" version?
Thank you for the reply. When ordering the housing from a Yamaha dealer it was the only option available and said it replaced the pump housing. I was curious why they made it one piece? Now having the 2 piece housings I will need some extra parts to put the 1 piece on my boat.
I wish you luck with the changeover. Not sure if you called a few different parts houses, if they'd know the difference, but at least they could describe it to you, so you could keep it OEM-ish.
Does Amazon have it? They usually have a decent Pic of the item
What was the final outcome of this project?
