- Raleigh, NC 27614
- 242X E-Series
Also see the FAQ on this topic (this thread is link #1).
Here is a list of the things you need to do to winterize your boat:
Highly Recommended:
- Fill up gas tank to not quite full (have to listen for it)
- Pull drain plug from stern and open all drains inside boat, and open all doors, raise seats (or remove)-you want air flow
- Add Stabil or similar fuel stabilizer
- Rev engines to blow out water (totally optional...pour anti-freeze in hose connection and bilge pump)
- Fog engines (there is debate on this--the worst that can happen is you foul your plugs--the alternative of a siezed engine is much more expensive)
- Lube main bearing (check out this FAQ on what needs greasing)
- Lube reverse gate linkages (2 points)
- Lube Steering linkage (2 points)
- Remove batteries and put on trickle charger (or trickle charge in place if you can monitor)
- Put "No Damp" or equivilant in boat (kitty litter was one suggestion)
- Cover boat
-Winterize any ballast systems or water storage tanks.
-Remove clean out plugs (Yamahas) and ensure no water is inside them (shake them and listen). If water is inside, disassembe to drain them.
-Trailer - check brake operation (try backing up with the harness disconnected)
- Trailer - check to be sure your hitch nut is snug (not tight) so your hitch doesn't come off the ball.
Recommended:
- Change Oil (doesn't have to be done for winterizing-can be done in the spring too)
- If you have a YDS cable and SW--read hours and record oil change hour, and check for engine errors.
- Change Plugs? (or better yet, do that in spring)
- Spray exposed metal with Yamalube Silicon spray (or similar) - Optional
- Check bilge pump screen and clean if needed
- Remove Carpeting
- If mice are an issue--cover all external access points (and consider dryer sheets or other remedies to fend them off)
- If mud-daubers are an issue--put golf tees in pee holes
- Lube trailer bearings
- Check brake fluid in trailer
-Check Anodes (stern and engine anodes)-replace as needed.
- Inflate trailer tires as needed - and/or jack up trailer and put on blocks (cover tires)
- Jack up axles and put blocks under and cover tires (optional)
- Clean boat inside and out (optional I suppose)
OK....what did I miss that ya'll do?
Highly Recommended:
- Cover boat
Recommended:
- Remove Carpeting
