Winterizing 2001 LS 2000
Jmuir
LS
Hello, First year with the boat and need some help on how to winterize the boat, do you have a step by step on what is needed to winterize the jet boat?
What is the fogger stuff called? Also am I needing to put antifreeze anywhere if so how so with the little garden hose connectors?
1) Fuel stabilizer in the fuel tank and im assuming run it through the engine etc,
2) Fog the carburetors
3) pull the plugs and put the fogger stuff into the cylinders
I appreciate all of your help.
1) I use stabil "storage" on my last run of the season. You can put it in and run on the hose as well but I like to limit time on the hose
2) fog the cylinders, not the carbs. carbs get the stabil fuel stabilizer. For fogging, remember to remove the safety lanyard and then spray fogger into each cylinder while someone turns turns the ignition on the key. Put anti seize on spark plugs and reinstall.
See my check list attached and below - copy/paste didn't work so well
Fill up with gas (89 octane), Mix with stabil storage ✔
Remove items (i.e. registration) from glove box ✔
Remove pull out plugs and store at home in basement ✔
Flush engines ✔
Fog engines (not on flush, fog until stalls or 15 seconds each engine) ✔
Empty water inlet strainers and lube gaskets ✔
Pour oil into each cylinder, anti seize on spark plugs ✔
Clean and wipe down engine compartment ✔
Engine compartment drain plugs out (manual says to store them in…) ✔
Pull battery and put on charger ✔
Spray engine compartment with fluid film/protectant ✔
Grease reverse gate and steering cables at rear of boat. Move steering and F/R gear lever to lubricate ✔
Clean and Wax boat
Condition seats mold/conditioner
Cover/tape the console covers, horn ✔
Grease trailer wheel bearings
Lift trailer onto blocks
Remove radio face and store x
Clear out anchor storage , ski storage, and windshield consoles ✔
Put dehumidifier container in boat
Fill trailer tires
Cover trailer tires ✔
Release winch strap tension on bow eye ✔
