- Ottawa, Canada
- Scarab
- 165 G
Hi folks,
I purchased my boat this year. I've been doing a lot of reading (including the section on the topic in the Scarab forum) on winterizing/maintenance and have various questions. If you're able to answer some or all, I'd appreciate your knowledge and experience.
1. Considering there are big, bright red letters indicating NOT to fog the engine but the entire internet (because I always believe the internet) and it seems all of Canadian boat dealers/shops fog... I'm very conflicted. Can someone explain why I should not fog? Every video I've seen including the one linked to in the Scarab forum fog the engine. Every shop I've spoken to fogs the engine including Rotax engines. I had never heard of not fogging an engine here in Canada until this forum. Keep in mind, my boat will be stored about 6-7 months with temperatures reaching down to -30C but hovering around -15C regularly (-22F and 5F for my neighbours down south).
2. If I do fog, do I use the XPS standard lube? Or do I use the proper fogging spray made by XPS... I've seen both being used in different videos.
3. To confirm, the torx bolt for the filter is an E-10?
4. I purchased a hydrometer to check antifreeze, if after 2 years it still reads fine, should I still replace it? Or should I always trust the hydrometer?
Otherwise in case you have any comments on the following, I've purchased:
- the MityVac 7400 fluid extractor for oil changes
- a small drill pump for antifreeze flushing
- fuel stabilizer
- planning on buying the approved XPS oil blend and filter
- planning on replacing my spark plugs every year
- the Genius G3500 battery charger/maintainer, battery will be in my garage connected to this
I think that's it. Sorry for the lengthy post... first time doing all of this, just want to make sure I'm good. I've watched the various videos on procedures, I think I'm good for the rest. Not planning on opening the pump/impeller myself... I think I'll get that done by a shop every few years.
Merci.
- fuel stabilizer
Merci.
