Wipe down after every use?
Chevyguy2021
Kannapolis, NC
Moomba
What is the best method for keeping a new boat in tip top shape?
We trailer. So pull it out of the water and wipe it down with hot sauce with at the boat launch? Or any other tips?
We get so many water spots that are so hard to remove. Maybe we will polish it this summer and then ceramic coat it to get a fresh start/good base in the spring.
That’s what I do.
I used rejex last season which helped but you’ve still got to wipe down every time or stuff will build up no matter how great your coating is.
Do you work for the boat? or does the boat work for you? (most likely somewhere in between)
Something you want to consider and decide early on to make sure your work/reward ratio is optimized. stuff wears out and your play time is very valuable. If my hull is a little duller, but I spent 2 more hours at the lake, that's OK with me.
HERETIC !!! :devilhorns: Actually, I respect all choices regarding boat finish care; it makes my mirror like boat look all the better. :winkingthumbsup"
I hit my hull with Hot Sauce and my seats with Vinyl Sauce after every use--takes about 15 minutes. I'm still a new boat owner so we'll see if that lasts forever.
Agree with this to a point. I can do one nice wax/polish a season and then it takes me 5 minutes to wipe the boat down at the end of the day. If I let it get out of control it takes much longer.
Some people spend more time cleaning than boating and some have 4 year old $70k boats that look like crap. Both of those are foolish in my view.
Unless you're in salt water!!! While this is my first boat in a long time, in my previous life and with my wave runners they get a soapy wash down each time we get back from taking it out. The saltwater evaporates and dries on the way back to the ramp even before I have a chance to wipe it down when taking it out of the water.
I just received by bottle of Rejex and will give that a try on the boat. I have used ONR and Optimum Spray wax which does a heck of a job on my waverunner but saltwater still does its magic at the end of the day. Let's see how Rejex holds up to the salty enviroment.
I'm not saying my choice is the right one...Just that owners consider what they feel comfortable with and the consequences of that choice (Many hours of cleaning? Premature wear?). I'm sure I'm a slob to many... I'm certainly not worthy of judging what sounds like an awesome routine that works for you.
Anyone driving faster than me is a maniac and anyone driving slower is a slow poke :-D
Always wipe the boat down with Hot Sauce after an outing. Will wash/wax the boat once mid season and wash/polish/wax in the winter (about to do it this weekend).
I do the same exact thing. My sons are in there teens and they actually are extremely helpful now, with wiping the boat down. Not so much when they were younger. We can get the boat wiped down and wrapped up in 15min.
Girlfriend usually drunk. My 8 year old helps and does a good job but he’s slow. So it takes me a bit but I enjoy the time usually. My wind down quiet time!
Before I had the garage built, I would wipe the boat down after every trip, once parked in my driveway, then cover with snap cover. Now that the boat goes into the garage after each trip, I still wipe it down after each use, but maybe just the interior, then the hull during the week. I don't seem to experience tough water spots from the Charlotte area lakes. but I do get a sediment film at the transom, and hull sides. My Gel-coat is still very slick from the care I've given the boat since new. I simply use the Eagle One wipe & shine detailer spray on both the hull and cockpit. In the last 5 years I've hand waxed it maybe 3 times, last year I high speed polished it for the first time with a 3" pneumatic high speed polisher. For me the small pistol style polisher allows for better control, and the ability to reach small spots.
Eagle One Wipe & Shine™ Detailer
Lakeboater. I wash and Rejex it at the end of the season. I don't worry about any short term cosmetic issues like water spots. I will wipe it down if I get a scum line. The inside is cleaned as needed. I tend to go out 4 to 5 times a week for 4 to 5 hours so I don't spend a huge amount of time on each outing cleaning the boat.
Hot sauce and vinyl sauce after every use.
I only do the daily clean when in salt. Otherwise wash about once a month in season after the spring wash/wax.
I'm OCD and grew up in salt, so my process is probably overkill for most people. I wash my boat inside and out after every trip, even in fresh water. ONLY exception is when I was at the lake all week last year and boat was on a lift, OR I'm taking it out again the next day. IN which case I'll clean it the following day. Boat gets pressure washed off, foamed, handwashed, blown dry, and then touch up with a microfiber for and drips. I'll flush the motors every couple of trips, unless it's salt in which case as soon as I get home. My new boat hasn't seen salt and my old boat had only been in salt twice.
I don't wipe down at the ramp because there are bugs and road grime between our ramp and our house. After every outing I hit the vinyl with some 303 cleaner and wipe down the inside.
Outside gets washed and waxed a half dozen times per season. I find that as long as you give it a good wax at the beginning of the season it'll stay clean between washings. When I'm washing the outside with soap, I'll scrub the inside tub and walls too and hose everything out through the scrupper.
Last year I did everything with a hose, bucket, and soap cannon. This year I added an electric power washer to my setup, which will be nice for the hull and rear platform to blast out that dirt.
