Wiring and ball size
rayg1022
We are getting a hitch for the AR190. can someone tell me the wiring is it a flat 4 pin. And the size of the ball for the trailer please.
It’s a 2 inch ball but I’m not sure about the wiring. If your trailer has brakes it’s probably a 5 flat. If it doesn’t have brakes it might be a 4 flat. Maybe someone else will chime in with a better answer about that.
Correct 2” ball and 4 flat without trailer brakes that are first offered on the 195 I believe and most dual axles...
190's don't come with surge brakes. You would need to step up to the 192 or 195 to get surge brakes. For a 190 it will be a 4 wire harness. All Yamaha's are 2" ball trailers.
