Wiring in fish finder 2022 FSH 210 Sport
tradenpaint
Hey folks,
I'm not an electrician so I'm needing to know what the best way to cut in my negative & positive wires from my Garmin to the back of the toggle switch (pictured). I would rather not splice. Any feedback out there? TIA
The Red arrow points to the switched terminal. Attach the hot or positive feed for your Garmin here.
The blue arrow is pointing to the negative terminal where you install the splitter or stacking connector. This ground is also the ground for the light inside the switch that illuminates when you turn the switch on. Attach the ground or negative for your Garmin here.
+1 for Blade Terminal Splitter. I probably use way to many of these ?
