Proudpapa
- 212X
My SB motor began overheating at higher rpms a couple weeks ago. Below is the info of what i experienced and solution from dealer. The sand may have come from running aground during low tide on the St Johns here in FL, which is on me. I pulled the engine anode myself and discovered it to be gone, which tells me the turd who owned it before me didn’t flush engines. Anyway, has anyone had this WORX kit installed to “help with sand buildup”???? And if so, how has it worked for you? I would also appreciate any feedback whether or not this upgrade kit is necessary or not.
I purchased in 08/22 with 22 hrs both P and SB. I put approximately 10 hrs on both motors before problem. I asked what the price would be without the upgrade (to clean sand out of both motors and the mechanic stated he will not work on it without the kit installed as it will defeat the purpose of the fix.
Any thoughts and experiences with a similar issue?
