Wicked92
- 255XD
Was out on my 255xd yesterday had 8 people on board, filled ballasts a lil lighter to play with my surf wave until i get my Gaitlin Fatsac. Issue is the way my connext works for water sports and namely the built in wake booster, you have to have a profile "Set" and running for the wakebooster to be deployed. No issues when i set the boat up lighter. The issue yesterday was as follows.
I have my WSL WSR profiles with ballast and their appropriate booster deployed, accel set to manual so i can change up the hole shot based on rider feedback, and my top speed at say 11.5. With 8 people in the boat and a lil less ballast cause i figured i had body weight, the boat would not hit target. 11.5 netted me barely 9mph and the wave never developed, the throttle is up all the way and the only way to try and add more speed is to hit the cruise "+" button frantically while the rider is suffering in the mess, then finally the boat tries to add more throttle, which then over shoots and you back it down a little and then the issue starts all over again.
Why doesnt the control loop in the connext not try and hit target? This boat as plenty of power to get there, its as if the control scheme clips at a certain amount of allowable throttle and will not try and hit target.
Theres no "manual" way to run either while having the wakebooster deployed. You are limited to 15mph and must have a profile set or the booster wont deploy.
Seems pretty stupid to have a boat you need to add weight to, which im fine with to get the better wake, but then the system cant even get there, when it does have the capability. This connext needs a serious update if this is running as intended.
