PGMills
- Other
- Other
Has anyone ever been told that a mechanical part (fuel pump) would not be covered under the extended warranty because the boat had not been used enough? [15 hours on engine] Had the annual maintenance done in June 2020, pandemic hit, took boat out June 2021 - bad fuel pump. $700 for repair. I think it's crazy they can tell you it's not covered because you didn't use your boat enough! Any suggestions, comments, recommendations?
