@Mbruce122 We have a 2020 SX195. I hope to be at the boat tomorrow, if so will take measurements and a picture to post. We have a small Fortress/Danforth "type" slip ring anchor - maybe a 4 pound. I think the Fortress F-& is very similar to what we have. If remember the F-7 is about 4-5 pounds and similar to ours - the length of the "bar" above your flukes may be longer than ours BUT but the same set-up would probably apply with a bigger anchor. The bar above the flukes of our anchor was almost too short to fit into the two composite blocks with black latches that Yamaha installs in the locker so I added two pins via ss screws to stop it from moving side-to-side (worked perfectly). I then put a piece of 1" foam under the flukes so they wouldn't bounce and damage the gelcoat in the locker. Finally I put a webbing strap with two suction cups to hold the flukes down to the foam pad. This works awesome. This small anchor is awesome for sand, gravel and a weeds - 90% of where I boat. I think I will add 8-10 feet of galvanized chain which I will put into a plastic container in the locker to keep it from scratching the gelcoat while stored. The chain should help the anchor stay set.What is everybody using for their anchor on a Yamaha 195. Does anyone know how deep the anchor locker is, ie will a fortress fx-7 anchor fit in it?
That's the first I've heard or seen of this. I've had the front of mine pound a few times, and my 22lb anchor just sits in there on top of the nylon line. Wonder if the shape of the anchor contributed to the damage? Maybe the waves were significantly harder hitting than anything I've been in? Definitely something I hadn't even considered until now.Yes you could knock a hole in the hull if a heavy enough anchor bounces around in there during rough waves or impacts. It happened to a buddy of mine on his way to Bimini with the group but they were in some pretty heavy wave conditions that year. This was with extra padding inside the anchor locker.
I’d find some way to secure your anchor in there to prevent it from bouncing.
Oh my god that seems terrible. Anyone have suggestions on what they have done with new anchors to prevent this?Yes you could knock a hole in the hull if a heavy enough anchor bounces around in there during rough waves or impacts. It happened to a buddy of mine on his way to Bimini with the group but they were in some pretty heavy wave conditions that year. This was with extra padding inside the anchor locker.
Hi kgower,@Dutch Do you still like the Mantus 1? I thought the roll bar was a key component of the anchor, but if it still works without it great. I had posted the member (can't remember name) who became a dealer and asked if it fit in the locker (a must for me), hadn't heard back yet. You just answered that question, yes with modifications.
We will be trailering ours on every outing. Thanks for the input.Hi kgower,
Yes I still like the Mantus 1 . I opted not to install the roll bar to get the anchor to fit in the anchor locker. That was a must for me, it had to fit in the anchor locker and also be able to secure it down. I trailer my boat on occasion and did not want to worry about it bouncing around in the locker bashing the hull. I know they design it to be used with the roll bar but honestly I never had a problem with it not catching without it installed. I always lower the anchor by the rode like you are supposed to and then back my boat up to set the anchor in the bottom. I suppose if you literally threw the anchor out it might land upside down tangled in the rode and not set right, but like I said I used it all last summer without the roll bar and never had an issue. I wish I had taken a picture of it this summer but now it is parked side of my garage in shrink wrap. I will take a photo this spring and post one as soon as it starts to warm up. The Mantus M1 8lb anchor was perfect for my AR 195.
