My STBD engine will get up to 8000 RPM on the hose but will not get over 6500 in the river. Is this an impeller issue? There isn’t a blockage and the clean out plug is intact.
Lots of things can keep an engine from max RPM under load. I would start with the throttle position sensor TPS and the Mass Air flow Sencer MAP both of these sensors could react quite different with no load verse loaded engine. MAP is really important to the fuel injectors output.
Nice thing is you can swap them off the good engine and see if it follows the sensor.
