Yamaha 2024 222SD Music Zone Control
Iddings10
222SD
Hey y'all,
New to the yamaha jet boat but we are having trouble with our music zones. When we have the cabin zone at 100 everything works as should but if you try to only play music on the swim platform zone it doesn't play any music. Any help would be appreciated!
Each zone I believe if I’m remembering correctly can be set from 0-100. So when you switch to just swim platform could the factory default be at 0 And you have to set it at 100?
I want to say when I got my 23 - when I was playing around with it the first time I was checking each zone individually I had to set it to 100—- but don’t hold me to that. If that doesn’t work just contact your sales person and it’s it’s not a big deal for this year just get it fixed when it’s in for normal punch out items after this season. You probably will have a few items anyway with a new boat.
@Iddings10. Take a look at this post thread. FlyingNugget and I have had similar issues with our 2024 Stereo Systems but have worked with WetSounds.
Did Flyingnugget and yourself have the same wetsounds audio problem at the same location on the swim deck speakers not working when u isolate that speaker zone? I’m just curious when I do my Bay test in the spring on my 24 222sd. I’d like to try and trouble shoot that away while I’m shaking my boat down
I experienced low volume and little to no bass from the sub. Did not have any missing zones. Once WetSounds replaced an amp and sent a dongle with the tune everything works as expected.
My only problem with the zones on our 24 222SE is that it only has two zones. We added tower speakers, a sub and 2 amps all Wet Sounds. The tower speakers are the transom zone and the 6 cabin and sub are on the other zone (cabin).
