kupper4
- Other
Wanted to share my instal as I’ve not seen much info out here for DIY-ers
2020 Yamaha 212s
Factory:
Fusion RA70 NEMA in swim deck
Connext touch screen
Polk DB 655 x4 in the cabin
Polk DB 522 x2 on swim deck.
NO amps
No Tower Speakers
Upgrades:
Fusion NRX 300
Wet Sounds Tower Speakers, Icon 8’s x2
Wet Sounds HTX2
Wet Sounds HTX6
Kicker Ground Distribution block
Kicker Distribution Block
Mounted Amps in Port side stern under seat on custom Amp rack made of 1/2” HDPE. Epoxy was used to glue mount pads to hull for safe screwing.
Had to upgrade wire harness on Fusion to add preamps. Also needed new gasket. FUSION MS-RA70 Mounting Gasket [S00-00522-19]
Had to run new speaker wires to rear cabin speakers to split them off from the swim deck speakers as they were in series wiring at 8ohm. Coupled factory connections to isolate swim deck speakers to be on their own.
Factory Connext system will not properly control zone balance and need to add Fusion wired remote. Basically, The Zone 1 and 2 sync to be equal with any volume adjustment.
HTX2 runs Icon 8 towers.
HTX6 Runs factory Polk’s
4 gage Tinned wire supplies distribution blocks and 6 gage to the amps. Battery cables USA supplied pre made custom wire.
So far the factory POLK’s are okay.. so ordered 2 pair of Wet Sound Rev 6’s and 1 pair of Recon 5’s to finish off the upgrade. Pictures to follow.
2020 Yamaha 212s
Factory:
NO amps
No Tower Speakers
Upgrades:
Fusion NRX 300
Wet Sounds HTX2
Wet Sounds HTX6
