agarabaghi
- SS
I'm trying to track down my overheating issue.
So far I have both cooling holes peeing off the side of the boat pretty evenly. Even once the alarm has gone off in the port engine and it enters limp mode the water temp coming out of the pee holes are pretty even.
1) cleaned strainers at jet behind the metal plate
2) cleaned intake grates.
3) replaced thermostats
I pulled the hose from the top of the oil cooler and ran engine for a second and water comes out (going to pee hole) so it seems like nothing is blocking?
Looking for ideas / sensor to replace?
Is there anything I can take a temp reading off to see where it's running hot?
