Tom Denion
- Canyon Lake Texas
- Limited S
Hello all, about 5 months ago I posted a YouTube video of my boat cavitating really bad especially the port engine, I finally got my boat out of the water, if you search [img 0529] on utube you can see it again too large of a file for here. After viewing the video there were some that mentioned that the port bucket may not be adjusted properly. Some history, the boat is kept at a marina and the shop at the marina pulled apart the port jet pump and said the impeller and wear ring looked good and the clearance was proper. When I got my boat back to my house I moved both of the throttle handles and the reverse buckets are both being actuated properly with the exact same positioning in the forward and reverse direction. Prior to having this problem, I did put on some jet fins which should not have anything to do with the problem I am having. Earlier today I pulled the clean out plugs which I had to tie a rope to and use a board to get the leverage I needed to pull the plugs, I had rebuild kits for each which I am going to fix tomorrow morning. As some of you may remember I live in a community that does not allow boats to sit out for an extended time so whatever I need to do I may have to move the boat to a storage facility to work on. I was an auto mechanic for many of my younger years so I can do the stuff myself if I could just diagnose. The shop at the marina charged me 250$ for checking out the boat for which they could not determine the problem. I could have replaced one impeller and housing for that price. I am not against changing everything impellers, housings etc. if I know the problem would be taken care of. My plugs definitely needed rebuilding, I should have done that when the boat was in the marina. Could bad clean out plugs have caused the cavitation you can see on the video. Note in the video the engines were running at about 4K RPM and the boat was moving 15 MPH through the water. I have about 5 days max I can keep the boat here otherwise I will need to get it out of here to a storage facility. I have all my tools here so I am hoping someone has seen this before and can advise.
