Yamaha 255XD surf point wedge not activate
bayliner
255XD
my surf point tabs not open
use this way
but not helped
I check all wire connections , then applied 12 V directly from the battery to the tabs drive - everything works -tabs open .
the control unit apparently does not receive a signal to activate.
boat in europe dealer has no experience with new boats
Did you click set on surf menu?
yes , try all
I see post is from 2022, did you got it solved? Curious to what was the issue. Sounds like the bcm maybe? Not sure if bcm also control the surf pointe.
I’d like to know that too for future reference.
