crowleyp
Hi all, I have a 2008 Yamaha AR230 with about 145 hours. I change plugs every year, ignition coils as needed. But I have had a recent unexplained RPM reduction, where both engines used to spin at 10500, then one , then the other can only max at about 8700 RPM. I checked throttle cable adjustment and they are up against the stops so no further adjustment. My intakes and exhaust's are clear, auxiliary cooling exits are functioning and the impellers are not cavitating. Boat receives annual maintenance oil change etc. Any suggestions?
