dadramjet
sea water filled the engine compartment and engines.
I removed intake and exhaust manifolds, plugs, all oil.
both engines had a lot of water in the above.
starboard engine would not start locked up pulling it now.
starter good prop shaft will not turn
port running but after 2 oil changes oil still white. no oil coming out exhaust
questions
1 should I pull the head or the pan when I get starboard out
what to expect?
2 oil change am I getting it all out ? sucked from the tank and the Tube that runs down to the pan
questions
what to expect?
