C Spez
Hello I am new to jet boating and new to this forum any suggestions are welcome.
I have a 2018 Yamaha AR240 I bought it new in July of this year, I had the 10 hr service done and boat does not have 50 hours yet.
Since day one the engines RPM have been different by over 500 RPMs and get progressively worse at higher speeds.
I brought it in immediately to the dealer who claims the throttles cables are adjusted properly, the lift gates are in line with each other and the pitch of the impellers is accurate, fuel lines are fine and air filters are clean,
but the issue of the RPMs continues.
Has anyone else experienced this too and is there a solution to getting both of the engines to run at the same RPMs without manually adjusting one throttle ahead of the other?
thank you
thank you
