Ohio Yamaha
- Wake
After using our boat for about 45 minutes it was shut off. When i went to restart it the engine was hard starting, but eventually started and the check engine light went on. I immediately turned off the engines and checked for and obvious problem (checked oil, loose wiring). I restarted the engnes and the port engine wouldn't go above 1500 rpm. I check the diagnostice code on the screen and got 1_6_ . I believe its the thermoswitch. It's a disc the size of a dime with two wires which attaches to the engine block with 2 bolts. Before I start changing multiple parts, can someone tell me if this is correct? Could it be a thermostat? The Yamaha dealer can't look at it for 3 weeks. I'd hate to lose that much time on the water.
Thanks!
Thanks!
