Yamaha Marine Grease
Jaybon3
Any alternatives to the Yamaha Marine Grease recommended in the manual? I think it is a lithium base?
My Yamaha dealer doesn't even carry Yamaha Marine Grease. They only sell Quicksilver 2-4-C, which is a Lithium base. I spoke to the service manager and that is all they use for all boat and trailer service.
I also use Lucas Marine Grease, which is also Lithium Complex and available just about anywhere.
Lucas Marine Grease is the only thing I use. Works well for everything
Grease isn't just grease. Some can be mixed, others cannot.
Lucas marine is a calcium sulfonate based nlgi no 2. This is probably what was used in your trailer bearings at the factory.
Yamaha grease is Lithium based.
B borderline
C compatible
I incompatible
Even though Lucas' website states calcium sulfonate, I have never seen it in any of the stores. The only Lucas marine I have seen in store (Walmart, Advance Auto, Home Depot) has been lithium complex.
Either blend is fine, since they are compatible. And as @marcham stated, Shoreland'r bearing grease is calcium sulfonate.
