Judge
- Cape Coral, FL
- 275SD
I did a search and didn't find anything so I thought I would post his for what its worth. I've found a reproducible bug in No Wake Mode.. at least in my '22 275SD.... or at least it doesn't behave as you might expect.
This is not really a big deal but if you put the throttles in the TDE position and increase the RPM's using the (+) button then move the throttles to neutral, the engine continues to run in fast idle instead of the RPM's dropping to normal idle.
I use No Wake mode when I am pulling into the marina and will use the buttons to control speed. Several times now I have had No Wake mode at the fastest idle speed and moved the throttles to neutral. The buckets go back to the neutral position but the engine RPM's remain at fast idle. The fast idle will remain until you either bring the idle back down with the (-) button or you push the sticks back to full forward and then return them to neutral.
I would expect moving the sticks back to neutral would deactivate No Wake mode and return the RPM's back to a normal idle.
