YAMAHA SX230 help needed
t1bray
OHIO
Limited
First up great site !
I have decided to upgrade from my Yamaha XR1800 to an 2008 SX230 . I found a clean 230 with verified 75hrs . Excited to bring home . Put down deposit .
BUT have a potential problem i need help with .
The issue is I need to know if the 2008 sx230 will fit under 7' garage header ? The SX / AR About the same boat .
I have performed a few searches but have found some contradicting information .
I looked at the caster mod but still not sure . Height on he trailer I believe is 7'6" can anyone confirm ?
I appreciate any and all comments .
And yes should have done more homework prior deposit :)
Mine is not stored at the house, but I remember right mine was 7'-2" or 7'-3" on a 2" drop receiver hitch when hooked up to the truck. I thought I would use a dolly and just lower it off the hitch to get it in and out till I saw it in person. That thing is not my 17' Carlson closed bow v bottom boat. It is way too big for me to push around. HA. 3-sided boat storage barns look cheaper and cheaper when I finally got to that point.
I have my 07 sx230 in the drive way right now I'll measure it for you.
I am getting 7'6" but I just replaced my leaf springs and my driveway is not level.
Mine would not fit in 7 ft. I have an 8 ft header. Garage door sticks down a couple of inches. I have a couple of inches of clearance.
thank you all for the reply . Very much appreciated . Now I'm really starting to worry .
Anyone try the caster mod to trailer to get it to fit ?
capt
YamahaForMe
mdwarchichoke
thanks for taking your time to measure . 7'6 is what I was told . Do you know if it will fit under 7' standard garage ? Maybe with caster mod?
Mine takes 88” to the top of the windshield, on the trailer with wheels.
Thank you sir . Is that with trailer level or lowered?
