123abc
- SX
Hi. If this isn't in the best forum for replys, please let me know! Thx.
2005 sx230. Bad vibration/noise at 5-9,000 rpm. I highly suspect intermediate shaft bearing (forward bearing?) where grease goes. We have never had a good feel for properly grease gunning this stupid thing and now I've read a tone more here researching our problem. I think we've been way over-greasing it and maybe blew seal. Pretty sure the problem isn't the pump bearings because we've replaced each side on those also and know the look and feel. We pulled the pump and bearings look good, well, "OK" I'd say - some discoloration of grease but not like when it went bad (only water in the cone seal at that time). So, we are planning to remove the inter. bearing housing and replace, unless someone tells me to check something else.
I have some specific question - I have read a ton here and on the "other" yamaha site on this, so trying to clear up some things.
1. Shims. When we unbolt and move the engine forward to get at the bearings, can someone explain the shims and how we make sure the engine sits back right when reassembling? I have read that one can unbolt either from the hull (two bolts each) or from the mounts (1 bolt each), but can this avoid the shim issue? Also, are there shims elsewhere - other than engine mounts? How difficult is it to mark them and get back properly?
2. Pulling the bearings/housing. Is this difficult and are special tools needed? Do I need a bearing press for this like the impeller bearing?
3. When looking from the back of the boat down the pump shaft "tunnel" where jey shaft removed, there is a white (looks like some sort of plastic or polymer) tube end with screws holding it in where the shaft enters the hull. On the starboard side (one with the problem) the outer part of this facing the back is gouged up pretty badly. Does this matter? What is this part? Does it seal the hull from water? Does it have anything to do with seal on the bearings (doesn't look like it does to me)?
4. Can someone find a link to a thread explaining the whole bearing replacement process? I have looked for hours, found some info but not enough to get the guts to tackle the job!
5. What part(s) do I need to order for this bearing/housing?
Also, is there any way to confirm this bearing is the issue? Can I run it in the driveway with the jet shaft/impeller out and listen? Thx.
Thanks much for any help on this!
