Yamaha wakeboard rack spring loaded handle replacement
Damsroy
LI Sound
I lost my handle in the water. Need a replacement.
it is a 2016 OEM Deluxe swivel wakeboard rack. I believe Part # SBT-RMRS-BK-14 for the rack.
Can't find part # for the spring loaded handle only
Thank you in advance
Nobody here had to find a replacement for this handle?
@jmargo as usual it was a combination of events...was getting ready to raft with friends in a cove and they wanted me to tied on the portside where the rack was. So i had to rotate it very quickly while the boat was moving and approaching the other boat. Was unscrewing the handle to fast and next thing i know the handle is in the water....
So you just had the threads sticking up ? I tried to separate my handle from the threaded rod but didn't have luck.
So now I understand.....The thread is supposed to be part of the handle? When you remove the handle the thread is supposed to come with it and not stay on the rack?
Yes, The area where the threads are missing has a roll pin going across it. Its the small hole on the bottom left of your circle. It could possibly just be thread locked on.
Did anyone ever find a good replacement for this handle. Mine broke and I need to replace it.
