Brandonloos_21
- SX
They just plug into the factory DSP harnesses that yamaha currently has plugged into their amps to let you use regular amps.How does this work?
OR, they plug into the DSP amp to be used with a regular (non dsp) system.
No, that should be plugged straight into your blackbox. These are just adapters to go from the amp plugs coming from the blackbox to rca's/speaker wireI see 3 cables... Do any of those connect to the RA70 radio that is in the rear?
Can't wrap my head around this. Can you tell me about more?Just wanted to share that I bought the main cable harness for my new install. I removed the DSP amp and replaced with 2 HTX6s. Added a second sub and replaced recons with revo 6s. Huge difference from stock. This was done on a 2020 212x. It is working great and saved me a lot of time not having to take out the head unit and deal with the fusion harness. Brandon was quite helpful during the entire process as well.
Yes and no. You can use this to connect as a pass through but you may still need a Audio control LC1. The head unit ( Conext screen) is sensitive to changes. Some have reports that it will shut down out put channels if the ohms are not correct. Needs to be 20kohms or more. So by adding a amp and parallel the signal to 2nd amp may be ok. You will need one that is male and female also zone out as need.I have a 2022 AR250 and trying to add an additional amp and 2 tower speakers. Plan on keeping the existing stock amp. Having issues connecting the new amp to the system. Would these work for my situation?
Are you doing a full replacement? No wet sounds 6ch?Hello,
Are you still making these harnesses? Planning on replacing the WS amp in my 2019 e series with a JL amp.
That's the end game but this year all that in the cards financially is the amp and maybe the sub. 6.5s next year.Are you doing a full replacement? No wet sounds 6ch?
Sorry, miss read your message. Yes, no WS amp. Completely removing it.Are you doing a full replacement? No wet sounds 6ch?
Yeah I am! Reach out to me, 7248846120. I see texts as soon as they come in rather than the pms here!Hello,
Yes, depending on boat, it gives the 3 zone signals out in RCA, plus a remote signal.I have a 2023 222SE. I have been trying to wrap my head around how to do my audio upgrade that I want to do. I was figuring just cutting in to the high level wires. But do these just allow you use RCA’s? How does it break down the signals?
