Yamashield on engines
JHC212X
Kelowna, BC
Moomba
I'm about to finish off winterizing the boat.
Just wondering if I should take off the engine cover and spray the entire engine with Yamashield? Spray down the spark plug wires?
Or just leave the engine cover on and spray what's visible?
Thanks
Where are you located?
That asked (because were I up north, I would probably be inclined to do more rather than less), I would probably still pull the cover. Very easy. Two screws and it pops off. Watch for the grommets that are in the cover through which those bolts go. Those tend to go missing if you don't watch where they are going...
