Yds info
Benoit
Attica NY
Does anyone have the proper fuel injection interval numbers? Length of firing in milliseconds
I’m having a running rich issue with starboard motor. Yds shows twice as long injector opening as port.
On all 4 cylinders. Tops of pistons are black like the plugs. Which are new this year. Port side pistons are grayish with clean plugs
I swapped ecus last night. Will hook up yds to see if the injector [HASH=536]#’s[/HASH] went with them tonight
Swapped ecus and fuel pumps. No change on injector duration. 6ms on starboard. 3-3.5ms on port. Not sure how ecu decides this timing but must read something like a vehicle uses a maf sensor
I have a 2008 and had a Throttle Position Sensor go bad. It had an effect on the timing at idle. You may want to consider that.
Did you save the output? Can you post it?
I can’t post output. Just a couple bad pics30A10108-D14C-4C58-9343-459B5BF3EEBB.jpeg9D4B3867-5FEB-43CF-A52A-A932B6EB11FE.jpeg
