BrandonC_OK
- Claremore, OK
I managed to get YDS up and running on my Win11 laptop and used the connect cable that came with the boat to download the data from the engines. As shared on another thread, I had to bump the engines over before YDS could connect and see diagnostic information from each engine.
Each engine is showing 21 hours! I guess when the previous owner replaced the ECM's, they reset to zero.
The only Diagnosis Record information of concern was an Overheat Warning 0.18 hours ago (about 10 minutes).
The last time on the water was at Grand Lake O the Cherokees in NE Oklahoma. We ran about 15 minutes from my cousins house to the boat ramp where we put in (6 miles by water, see map below). I would guess that 10 minutes before shutoff would be when we slowed for the no wake zone under the bridge. It was after dark and I don't remember seeing any flashing lights on the tach/speedometer so I was surprised to see this in the report.
I don't know what a "normal" amount of water out of the pee tubes should be but I don't get very much at all under idle. I hooked a water hose up to the engines (yes I followed protocol) and while running at idle attached to the hose, I had strong flow from the aft most pee tube and revving the engine would throw water out of the front pee tube (exhaust). I've removed all four pee tubes from the motor and blown them out with compressed air and running weedeater string through them. I even double checked by blowing air with my mouth and found no resistance. I've watched the YouTube video on how the cooling system works (great video BTW) and grabbed a screenshot showing the three areas near the jet nozzle where cooling water exits the boat and while hooked up to the hose running the engines I had lots of water coming out of all three areas with very strong flow out of the lower left hole.
I checked the intake screens inside the nozzle and they don't appear to be clogged.
What should I do next?
I was going to remove the housing for the intake screens to make sure there isn't anything in there. I believe it was in the video above where someone had plastic inside the Y fitting they had to remove to solve there problem. I guess I could start making my way through all the hoses on the cooling water system and make sure I'm getting flow through all of them?
One more thing - while running at night about half of my gages didn't have a backlight. Is there any way to address this without replacing the whole gage?
Thanks everyone.
Thanks everyone.
