YDS version needed for a 2016 242 limited e series?
Andrepiedra
242 Limited S E-Series
Hi!
I keep getting a port check engine alarm, dealer erased it but it keeps coming and wont let me rev the engine more than 6k. I wanted to buy a cable to scan it by my own but the ones I see on ebay are version 1.3 and im not sure they work, anybody knows? If not where can I find the newer versions?
Thanks in advance for any help!
You cant just buy a simple cable on the newer stuff.
This is probably the cheapest diagnostic tool.
Yds pro2
Thanks for the help. Talked to a seller on ebay that has the 1.3 version and says that in a month he will be selling the YDS 2.0 for $99.
YDS 2.0 for $99? Can you elaborate? Did you get your hands on a device that works?
Got the 1.33 version for my 2015 and it does not work. Says it's missing file se2017.dbf.
Maybe an update database would work, if it exists.
I had the same issue... have you found one that works with the 2016 model?
Go yo my post #2 above
Went up a lot. Was 250 when i bought it
