jEt_jAk
Jetboaters Commander
- SoCal
- AR195
Looking for a better cooler to put under the bench, I have the AO Stow N Go which is an awesome cooler for under the bench but it’s awkward size makes it a pain in the ass to carry around especially since it does not have a shoulder strap. So I wanted to try the Yeti Backflip. (Hint: the RTIC backpack will not fit, it’s wider)
I was a bit worried about the zipper leaking water but it’s a watertight seal so should be ok. Plus it’s a boat if a little water gets in I’m sure it will be fine
What I found is it is a pretty tight fit but it works. The shoulder straps make it a bit tight but if put under seat vertically, it works quite well and still leaves room for other items under the bench:
