Slfmde
Was doing the 10hr maintaince greasing the bearings in the pump and the zerk fitting broke off leaving the threads in the housing. First one went ok but the second fitting would not come off no matter what I tried. I loosened the two halfs, removed the hose from the pump nothing worked. After 45min it just snapped off. The zerk still won't come out of the fitting at my bench.
So now figuring out what to do. Does anyone know what size the zerk is? Seems like 8mm is better fit then 5/16 but there isn't a metric removal tool.
Edit: Would something like this work https://www.tractorsupply.com/tsc/p...se-fitting-repair-tool-for-1-4-in-28-fittings
