‘23 195S - Can I Drill Here?
TheArk
Madison, WI
195S
Posted in the 19’ forum, but thought it might get more visibility here.
Looking to mount some audio equipment in the starboard aft storage compartment of a ‘23 195S. Anyone know if it’s safe to drill into the floor here (~ 1/2” - 3/4”)? What’s under there?
I would assume that’s the hull based on the ridges from the hull chine.
Open the engine bay and look. You will either say a space under that spot, or where the carpet meets the hull.
I would suggest either industrial velcro to the carpet, or pull the carpet up and use a good epoxy to the fiberglass. But if you drill, go big. It will be easier to see if it leaks.
Did some rudimentary measurements using a 2x4 rested on the wake tower. Looks to me like there’s around 3” between the storage floor and the lower hull.
That makes sense - the starboard-side storage floor is the same depth as the port side storage floor and the battery sits couple inches lower than the starboard side floor.
So … my guess is there’s nothing but a few inches of foam and stringers under there.
