- Corinth, TX (DFW)
The momentum is slowing down, the hood insulation and window wipes and fabric for the sun visors are all still sitting, waiting for installation,
Got the 4wd drive working momentarily, it was bucking, turns out the transfer case is bad and parts are very hard to find, couldn't find any local shops in DFW to rebuild so having to order from a jeep guy in WA.
since then the 2nd row window started sliding down, luckily the window track is so old brittle it only allows it to fall half way,
we spent yesterday pulling the panel and replacing this plastic chain/track that works the window, it had broken at the window attachment,
while fixing the window, the arm rest/door pull broke, the brittle plastic that the screw passing through cracked.........
