Michael Guzzo
- Tampa Fl.
- Limited S
Hi all. You may remember me from a previous thread as the guy that was deciding between the 2012 242 Limited S and 2014 with a sun damaged interior. Well I decided to go with the 2012 and things have not gotten off to a good start…
Yesterday I picked the boat up from the dealership and headed directly to the ramp with a crew of 4 as excited as can be. Dropped the boat in the water and headed out. Before we run I try and set up the new Bimini they provided me to find out it was installed backwards. This was only the beginning.
About a quarter mile into our trip I start to feel that something is off with the boat. I look back and notice that the rear deck is slightly below water level and immediately realize what the issue is. Open the clean out port compartment to find that one of the ports had come dislodged or was not in at all (I should mention that during the water test the same port came dislodged but the sales person sitting in the back noticed immediately, put it back and we were on our way). I try to turn the bilge on and am not getting power. Not realizing the danger I turn the engines back on and slowly head back to the ramp. After the boat is out of the water I look in the engine compartment and see that it is about ½ full of water. I decide to head directly to the dealership service center. By the time I arrive the water had drained out but when he opened the casing which holds the air filter water pours out and the engine oil is milky. The mechanic says that at a minimum we need to do a boil out procedure ($500 per engine) and replace both air filters ($180 per) and whatever else they find. I describe the bilge issue and after he investigates it turns out that the batteries are wired in a way where all 3 switches (including the emergency parallel) have to be in the on position for it to work.
On the way home the sales person calls and is completely apologetic and says they are taking care of everything and I have no monetary obligation in this. I have had so many other issues with them but for the sake of not making this post longer than it is I will spare you.
I was hesitant to post this and slightly embarrassed because admittedly I probably should have noticed sooner and stopped the boat earlier but being that this was my 1st time taking it out (or owning a boat at all) I was not completely in tune with how the boat should feel. Now I worry about the long term damage done to the engines. I need to read the fine print on my contract when I get off work but also am wondering if I have the option to just say thanks but no thanks and give them the boat back.
Thanks for listening. I hope to one day have a good jet boat story to share with you all!
