Thanks. Happy to be here! I'm a complete DIYer so any trips to shops are a last resort. This Yamaha set up is still a learning experience. After a little more tinkering I think I've just about verified it to the ECU. I swapped the #3 and #4 injectors and #4 is still flooding. As a 100% confirmation, I'm going to swap the ECUs between the engines and see if the issue goes with it to the other side. Oh wait. I don't want any fuel in that oil so I may just throw a gauge on the injector lead and see if it's sending constant voltage. Hoping for a loose connection or some corrosion on a lead. Probably a long shot. Anyway, I'm looking into that CarmoUSA.com since it looks like they can repair them for about $353. Has anyone else had any luck with them? Sorry, don't want to hijack this thread but there's some really useful information here.
Thanks again,
Robert
It's my understanding that a bad injector can cause the ECU short. Ohm test your injectors before running with the new ECU.
