pictures?
Thanks @cybuch and good luck with the testing. From what I've seen, read and heard there are slight differences in the path of cooling water flow between your engine and my non HO engine. On mine it appears on that the water inlet splits and sends water directly to the oil cooler, block and exhaust. The water exits the oil cooler behind my thermostat housing and then goes through a hose connecting down line in the exhaust. It looks like you could easily block off one of those hoses and set a gauge on the other to test it out. I'm really curious as to how you block things off and what gauge and valves you isle for this. Thanks again for keeping me posted.@itsdgm I was going to start at it this weekend, but my football-self just didnt agree. I will most likely start at it next weekend. I am going to attempt to pressure test the block, I will have to figure out some way to block the exhaust ports. Maybe build a metal plate and bolt it on. I will snap some pictures and keep you posted.
@cybuch I was thinking about how to seal off your exhaust after my air pressure suggestion. I would take off the hose going to the water boxes. You should be able to get a plumbers plug or possibly a kids inflatable ball to put in the outlet and inflate it to seal it off. I seem to remember my dad (plumber) had different sized plugs he would use to seal off pipes to pressure test.@itsdgm I was going to start at it this weekend, but my football-self just didnt agree. I will most likely start at it next weekend. I am going to attempt to pressure test the block, I will have to figure out some way to block the exhaust ports. Maybe build a metal plate and bolt it on. I will snap some pictures and keep you posted.
Good luck with this @cybuch im following your progress. I ended up with a cracked block on my cooling water jacket. After several unsuccessful welding attempts verified by pressure checks, I've decided to replace the engine with a similar hour used engine. That way I can rebuild mine later when I have more time for such a project. It appears that my block cracked just below one of the head studs. I believe this to be as a result of a weak casting of the block that cracked when I had the head worked on due to a stuck valve. So be careful when you tighten down the headOk, I finally got back to this after all kinds of home projects. I decided to do a compression test and I found that cylinder 2 is %75 of the other 3. I am thinking I may have a cracked head. Going to pull the motor next weekend and pull the head.
Ouch. I agree with your assessment @cybuch that yours is probably split inside too. Does that crack correlate with the piston that has low psi?Well, motor is out and I think I found my problem, cracked case. Not only am I getting water in the oil, but I am also getting water coming out of the case. I guess a call to SBT for a new motor.
