WREKS
- Port Saint Lucie, Florida
- SX
Along with these helpful suggestions, running on the hose in No-Wake mode for a few minutes is my preferred way to flush.
However, in my experience, almost all my problems with overheating trace back to residual water left in the cooling system after flushing. This wet environment is favorable for microbial growth that can build quickly in the cooling system. Once it builds up in the cylinder water jackets it is not going to be flushed out. Now, I try to dry out the engines by running them without hose water for a minute or so every few days until I think they are dry. It does not hurt to run engines for a minute or so without water.
That may not be your problem, but that is why I suggested that you take temperature readings when you are running on the hose. That might help locate hot spots below the exhaust manifolds. If you are getting near 200 + degrees that indicate s a blockage.
