2014 AR190 - Alarm code - help :(
Yeah mine was the sensor in the exhaust. Fixed
Hey thanks, that sounds like something I can replace myself.
Based on your profile info...you have a different boat than Vito....so not likely that they'll be the same issue (but possible I suppose).
Hey no we have the Yamaha Ar 190. When I made our profile page we had a deposit on the scarab. My bad I'm trying to fig out how to update profile so I don't cause any confusion.
2016 AR190 - Check Engine, code help :(
I got Yamaha Trouble Code: 15 (52 1018), any ideas?
Temp Sensor malfunction...is it a California emissions boat? You can run the boat through 3 full start up cycles (start, shut off, let it power down completely) and see if it clears itself, otherwise you've probably got a failure.
Yes, it's a CARB boat. The error code eventually went away after all day on the water but it happened twice this season. No issues with performance while the code was active. Also seems to come up after I try to start the boat without safety lanyard.
OK, thanks! It's still under warranty, I'll have my dealer look at it while they winterize the boat next month.
