Mainah
- Chapin, SC
- Limited S
@swatski The one you posted is dead nuts simple and may be the best way to go. I do agree with @KXCam22 though in that probably a unneeded complexity. Here are a couple of other options if you decide to go with timing ....
https://www.amazon.com/DROK-Digital...8&qid=1489771603&sr=8-18&keywords=timer+relay
https://www.amazon.com/THC15-DC12V-...UTF8&qid=1489771816&sr=1-6&keywords=12v+timer
https://www.amazon.com/FAVOLCANO-CN...UTF8&qid=1489771816&sr=1-4&keywords=12v+timer
https://www.amazon.com/Baomain-H3Y-...d=1489774321&sr=1-19&keywords=12v+relay+timer
Choose your own switch/dial and housing DIY option ... This is the simple method of what I would do if I did this but requires more electrical components and soldering but is a self contained solid state IC with wire leads.. https://www.amazon.com/Timer-Delay-...TF8&qid=1489771816&sr=1-10&keywords=12v+timer
Last option would be a Raspberry Pi or Arduino with a motor control shield and get your own potentiometers. This is what I would do if I did this because I could control with hardware switch on my phone plus monitor fill levels and other cool stuff. Requires programing the board and plenty of wiring so perhaps not the best option for most.
I have decided when I do mine to keep it simple on the control side and just install 4 rocker switches. I will go all out on the power distribution and relay side but thats just who I am. On the plumbing side I am not too far off from @swatski in my thinking and can't wait to see what he does.
