Compatico
- Other
- Other
It's common sense, follow the manual intervals for oil, tranny, transfer, and diff because the manufacturer knows how to take care of their gear under normal or infrequent use. But change early if you're stressing the fluids with heavier than recommended use. If you tow every day or tow near limits, then change early to prevent wear. If you tow at less than half capacity, or tow a fair distance once a month near capacity, you can probably stick to the manual's recommended intervals as you're not really stressing the system and fluids. If you only tow at 50% capacity once a week but load up the vehicle with max cargo and passengers when you do, then change early because that is stressing the system.I got a 2016 F150 5.0 4WD with a 6 speed transmission. After 3 years the truck has 57,000 miles and 45,000 miles are towing (less than 6,000lbs). So I was thinking to change the transmission, transfer case and differential fluids. I looked online ( see link below) and it says that I should not bother until I hit 150,000 miles!!! is that for real ? or is Ford playing tricks on me?
Remember that most vehicles have ratings based on minimal loads like one occupant, 10% load, and under 50% trailer capacity. Just like tire pressures are based on one occupant and no cargo in the vehicle. As soon as you increase these load numbers, you need to compensate with more air pressure or more frequent maintenance as needed.
Don't forget that changing fluids is very inexpensive for dealers, and costly for consumers = high profit for dealers. Change your fluids early if you're a moderate to heavy hauler - don't if you're not.
