Maybe others have already seen this but I just discovered something weird about how my system is set up. Coming out of the head unit are RCA line-outs for the front channels and the rear channels. There are no RCA line-outs for the subwoofer (unlike some other HUs).
I had assumed that the RCAs for front channels were connected to the front channel on the amp (Polk 5000.5) and the rears to the rear. And that nothing was connected to the sub inputs on the amp. There’s a switch on the amp that allows you to choose between dedicated sub inputs or what they call “INT” if you don’t have RCA outputs for the sub from the HU.
When I recently looked the amp settings, I noticed that there were RCA cables plugged into the sub inputs on the amp. I’m thinking to myself “how can that be” so I followed the cables back to the HU and discovered that they were from the rear channel line-outs. Then I tried to see how there could also be RCA cables plugged into the rear channel inputs on the amp and found out the Yamaha had taken the front channel outputs from the HU, attached Y-cables (see attached picture) to the end close to the amp and then connected them to both the front and rear inputs on the amp.
Does this make any sense? To me the answer is no but maybe there is logic in doing it this way that I don’t see.
Many thanks.
