- Florida
- Other
- Other
ok sounds like it is starving for air or it has water in the fuel so see if you can check what I said previously
ok so no silver color and that is good now you need to run the engine with the filter first and if it still runs poorly try without the air filter and see if that works better.Mostly light brown with a little hint of black
How many hours are on the engine? and are any of your hoses leaking water it looks like signs of water leaking on the front of the engine , also I would check on the fuel pump pressure and all the main ground wire connections to the engine block should be unbolted and cleaned then reattached. negative connections corrode bad if water gets on them ,looking at the picture it may have some loose hose clamps. And any leaking hose clamp can be an issue plus any leak in the exhaust is bad.
There's no leaks anywhere. I believe your arrows are pointing out how certain metal parts react to exposure to the Florida air. The boat was near Orlando and my place is about 12 miles from the Atlantic.View attachment 215707 ok I see possible issues, also that low of hours in 7 years is leading me to suspect the fuel quality again I see boats loose power if they just sit 1 winter with low fuel and your tank is not sealed so moisture gets in the vent and can condense in the tank Also clean the grounds and try removing the air filter just to see if it runs better without it just as a test and any rust on the clamps I would replace them with good ones , one loose hose can sink your boat.
