2018 Yamaha 12.3" Connext System - Bluetooth Issue
Did they fix the 12" screen so you can see the gas gauge when the engine isn't running....that is one of my pet peeves with my Connext.....go to get gas and can't see the level once I've turned it off.....stupid.
Gas and depth always displayed. You gain water temp & audio info with engines off
Yeah, I was watching the level last weekend while I was filling up. Hope to get out this weekend, but weather here in Raleigh area is looking very rainy. Sucks any weekend.... really sucks when you've got a new boat and it's Memorial Day weekend and you want to be on the water....
I'll admit, that I was a little confused when I first saw the post about the fuel level not being able to be seen after turning off the engines. I went back and made sure that all released versions of the software worked the same and they did in regards to the fuel gauge. It is always present on the left hand side of the 12.3" display and does not leave when you shut down the engines. The only possible way I thought of that something similar might happen is on the 242-LTDS, when you turn both keys off to shutdown the engines and you do not turn them back to center. Then the engines will shutoff and the system will shutdown completely, but if you just turn them back to center after the engine is off, it will keep the system from shutting down.
The fuel level does not show on the 2015-2017 Connext when the engines are off. I can confirm for my 2016 AR240. Unless I'm looking at it wrong, which is entirely possible, lol.
Personally, I tend to use "gallons used" and that indicator does show at all times, trick being to reset it while filling up (and it is not useful for partial fill-ups). But not being able to see fuel level with the system on is an issue.
Now I understand. Since the 12" display was called out, I thought he was talking only about 2018 models.
Yeah it definitely shows. Gassed mine up at the dock last weekend and one of the kids was keen on reading off every number from 37 to 100 while I was pumping....
So, this worked..... Pressing that button with the 3 lines did it. When I initially did this, I just got a message that said loading. I wasn't very patient and only waited a couple seconds before pressing another button and switching screens. I was out on the boat yesterday. Pressed that button and it took probably 10 seconds. After that, the "Discoverable" option came up. Pressed that and then RA70 showed up on my phone. It worked just fine..... guess I need to learn a little patience. DID NOT have to mess around with the rear controls. Did everything on the Connext screen.
Uploaded a picture of the screen after I got it connected.
I have a 2016 242 S. My radio is doing the same exact thing but I don't have the same menu you mention. Anyone with a 2016 have instructions?
Has anyone had any issues with all the media components on the connext screen being locked and unable of being unlocked?
Turn the radio off at the back. Turn the radio back on from the Connext. That should do it.
I’m having a heck of a time, right now. Had some low voltage on my batteries after a couple stormy days and not being plugged in.
After charging up, all the other communication errors went away. But, I can’t turn the radio on through connext. I can turn the head unit on/off and see that Bluetooth is connecting and songs are playing. But, it won’t turn the amps on. Connext just says “turn stereo on” and the button does nothing. All the media selections have a padlock.
At this point, I’m ready to just take it to the dealer at the end of the season and use my little Bluetooth speaker for the rest of the season.
Still no luck all media on connext media screen stays locked, even if I shut the swim deck unit off. It will not unlock at all im dumbfounded someone help....lol
2018 242 limited S Im having issues pairing anything to the media tab on the connext screen...I can pai to the deck unit but all other media on connext screen is locked...I am also throwing communication error depth transducer see attached pic. Ive disconnected the batteries and adjusted the depth gauge with no fix...can someone help...im also having issues unlocking the media components if anyone has a fix for that...thanks in advance
On my 2018 242XE once I hit Bluetooth I connect to Bluetooth RA94 on my phone and I’m in.
If you’re getting those communication errors, you probably need to charge your batteries. That cleared up this issue for me.
But, I still can’t get Connext to recognize the radio is on either. I’m afraid I’ll be getting a new Connext screen in the off season.
