Hello everybody I just bought the new yamaha 195s and the audio system has a lock on all the sources im trying to turn on but nothing happen....... any ideas???????? Thank you in advance
*** I was able to fix it very simple: The radio in the back (MAIN) is the one you have to remove the screws (4), 2 by each side after removing two covers. Take the covers out with a flat screwdriver and then proceed to unscrew. Pull the radio completely out, and try disconnecting the power cable, clean, blow, and plug back again. Most likely water came in or became lose. Also, check the fuse, but this is very unlikely, but just in case if it does not turn on. Then go back and screw everything again... and all set.
