'21 Yamaha AR 195 Lucky 13 Cone Install - Cone Missing T Engraving
Wick3d3vo
Recently purchased a used '21 AR 195 and have started working on upgrading a few tidbits. The lucky 13 cone was one of the upgrades I purchased, however, I do not see the T engraved like expected. Is there another indicator I can use to ensure correct install??
Tough to tell but have attahced pics of all 4 points.
Removed the stock cone. Obviously the lucky 13 is directional. Any indicators to drive that?
Alright...nvm. need to remove the cone first and "top" is right there. Rookie mistake, smh. Attached a pic for reference.
These cones came on some jet drives that I purchased . I pulled the removable tail off to check if there was anti seize it seemed to be kind of loose was there a torque spec ? And does that bolt pass through into the bearing area ? I remember another member posting that the bearing went bad from water infiltration, he mentioned from removing and re installing that he must have pinched the o ring. When you pull the tail off there is a small o ring and it has me thinking, was that the o ring he pinched and its there to keep water out of the tail piece bolt.
