sfransko1
- 212XE
Hi Everyone, I have a 2021 212XE and had similar issues with my port engine rpm. Here is what I received from my dealer once they connected with Yamaha, and I haven’t had an issue since.
1 - make sure the boat is never turned off with the throttles not in neutral...this will directly cause the issue that you are having because the gates are not in the correct position when the boat is turned on after the shut down, so they don't calibrate correctly... the boat is basically doing a calibration on certain items each time its started.
[HASH=6052]#2-make[/HASH] sure to turn the key switch off, wait about 45 seconds for the connext screen to shut down and then turn your battery switch off, don't ever turn the battery switch off while anything is still on the connext screen ...its like yanking the cord from your computer while its on... the system needs to be properly shut down so that when its restarted - it can do its normal calibrations...
This all worked for me and had no issues at all. The key things are letting the connext system boot up and calibrate everything and make sure you start and shut off engines with the steering wheel straight and you will have no problems at all
