- Raleigh, NC 27614
- 242X E-Series
Are you certain all the battery wires are connected?
i havent tried but i would like to ask why do you think that will change something?Will it turn over with the plugs removed?
Ok so this morning I checked the starter solenoid and it was bad so I swapped it with the good one to see if the engine would start. now it seems like the engine is seized as well because I hear the starter try to spin up but it cant.
I hear the starter engage and then after a couple seconds it sounds like its disengagingIf you're just hearing the starter spinning, it could mean that it's not pushing the starter to engage the flywheel. Can you hear the starter click out? Or is it just spinning in its place?
Give me a call, I'll PM you my [HASH=5]#[/HASH]I hear the starter engage and then after a couple seconds it sounds like its disengaging
No, but I was only with the boat for 4 days and I cant work on it anymore for a whileDid you get it figured out??
Where do you get this book?Let me know if you need more detail from any of these...
