swatski
Jetboaters Fleet Admiral 1*
- North Caldwell, NJ
@Bryan L Hopefully you got the right part kit, they changed the intake manifold back and forth around 2014/2015. It is posted somewhere here.Sysinu, Thanks again for all your help. I was able to talk to SVM and it looks like it is a possibility to have them repitched for 5000' under warranty. I also picked up the RIVA intake spacers and K&N filters. One question I have concerns the orientation of the RIVA spacer. I watched your video on Youtube (great BTW), I believe you indicated inserting the spacer with the arrow pointing the motor (with air flow and how every other uses the arrow to determine air flow) and not to the throttle body like the instructions. Am I missing something? I noticed these instructions use an older boat for reference.
I just did mine some time ago, installed those in the direction as per instructions. Also removed the "snorkels" which helps the air flow, no need for better air filters after that.
